Tps and rpm wires on pcm
Old 06-29-2009, 08:29 PM
1320 killer's Avatar
Default Tps and rpm wires on pcm
I am working on a 2004 ZO6. what wires do I need to tap into to get the rpm reading and the tps reading. Thanks in advance to all that can help.
Old 06-29-2009, 09:21 PM
SkullV's Avatar
Blue wire off the TPS sensor and then I got my RPM signal from a white wire in one of the connectors on the driver side of the motor (may be different for the vette, but should be same motor and PCM).
RPM Wire:
Old 06-30-2009, 06:09 AM
nikon1999's Avatar
i know on a 99 computer its pin # 10 for tach and # 24 for tps. White wire and a drk blue.
FYI - I was always told never cut a factory wire if you can help it, just pull some insulation away and solder an additional wire onto it.
