wet kit hook up. using fpr?
i have an aeromotive A1000-6 Injected Bypass Regulator P/N 13109.
according to this site
http://www.aeromotiveinc.com/pdf/13109.pdf
both sides are inlets. and the bottom is a return. i currently have 1 inlet and the return being used. the other inlet is plugged. is there anyway it use the "inlet" as an "outlet" to feed the gas selenoid?
