Wide band o2 sensors for C16???
I have an Auto meter wideband and run C16 with my wet system.
I believe the sensor is shot because during the run the wide band sticks at 14.7 and does not start working untill the car cools down. (20 min.)
Who makes a sensor that will handle C16 race fuel
Thanks
Thanks
Your sensor is shot. A new sensor will probably work for a while with leaded fuel. As far as I know Bosch, Denso, and NGK are the only manufacturers of wideband sensors. You need to know which sensors are compatible with your controller (meter).
