wet nozzle questions
Old 07-20-2009, 11:19 PM
johnLs1camaro's Avatar
Default wet nozzle questions
Is the nozzle position on a wet kit a big deal. I use to have a dry kit and it seemed like where you put your nozzle made a big difference. I understand that a wet goes after the maf, but just didnt no if it mattered much after that?
also I put my nozzle in my bellow and it seems like Its got a slant to it where when i spray it, itd probably hit the side of the throttle body, but i cant get it to spray straight its like the lines push it that way. So im wondering how you all setup your nozzles to hold up straight, besides using a plate.
sorry for the newb questions.
Old 07-20-2009, 11:30 PM
jmill96Z's Avatar
You have the nozzle in the right position, but it needs to spray straight, not into the side.
Old 07-20-2009, 11:36 PM
yeah, thats what i figured. Im just needing help on getting it mounted right, cuz i cant fix it from turning. does everyone use those bolts that go onto the nozzle and then one goes onto the other side to hold it in place? I figured if I could find a way to loose that it may work better idk.
Old 07-20-2009, 11:49 PM
jmill96Z's Avatar
Honestly, the way I fixed mine was to get a smooth bellow.
Old 07-20-2009, 11:54 PM
haha yeah i thought about that, I just hate buying one.. I had a fernco laying around and looked it, but its way too think. Is the slp bellows not really thick?
Old 07-21-2009, 09:45 AM
Nick@HSW's Avatar
The SLP bellows is thick but its molded to fit your car perfectly. That's why I recommend them to customers.
Nick
Old 07-21-2009, 10:57 AM
RsSean's Avatar
Your lines maybe pulling on the nozzle causing the angle.
