Nitrous set up
Nitrous set up
Im running 12.8 on motor with no internal engine mods...no long tubes on street tires....what would be the highest dry shot i could run without messing with fuel pumps and injectors?
my buddy has a cam only a4 that ran 12.1's and on a 100 shot spraying somewhere during the 60 foot ran a 11.40 with the shifts all messed up. now hes running 11.7's with the same mods and better shifts, so were hoping to run 10's on a 100 shot.
Look at my sig. I have the stock fuel system and manifolds. I run about where you do on motor and it looks like we have simular setups with what little youve told us about your car. I see your new to the board , you should add all your mods to a post like this or better yet make a signature that shows your mods. How your rearend holds up has as much to do with what tires you use as spraying out of the hole. IMHO I spray out of the hole with slicks on a stock 2.73 rearend. How long it holds up is hit or miss.
