Nitrous OutLet direct port system
hi , i seen two direct port systems from Nitrous Out Let 60PSI , i want to know what is the difference between 2 solenoids and 4 noids
As long as the solenoids that flow well enough I don't see a problem. Ask someone from Harrisworks or Nitrous Outlet. Both are very helpful and will be able to give you a definite answer.
Im running the N20 OUTLET D.P. 2 NOID They are good up to 400 hp no problem if your spraying a 400 shot you better have hell of a motor lol.
Talk to DAVE or Chris man they will get you set up on what you need for your application. They did an awesome job on mine and had it sent back to me within a 2 week time frame for me to go race. And the hard lines look sick when you open the hood and are all pefectly lined up.
Guest
Posts: n/a
Yes
It cam with 100 200 300 400 jets. I also called Dave and bought the 250 jets extra so I could tune the 200 then go to the 250 see how that goes then up to the 300 to just be safe. I just started with the 250 jets.
