2 heater pads
Old 11-21-2003, 10:00 AM
bigSS's Avatar
Default 2 heater pads
I have an NX 15lb bottle with a Dynotune bottle heater. I don't know if its because I have a large 15lb bottle, or what (this is my first nitrous kit), but it takes wwwaayyy too long to heat up. I need to figure something out. Can I wire a second heater pad on my kit? Anyone do this?
Old 11-21-2003, 10:56 AM
slow's Avatar
you can do that... but just make sure the amperage ratings are watched.
the dynotune heaters are 300 watts right? if so, you will NEED a second relay, wired in parallel to the other one.
So the 1 thermostat/pressure stat, will control both relays.
Ryan <-- i have wired this same setup, on a dual NX heater pads, on a NX Carbon Fiber bottle.
Old 11-21-2003, 11:14 AM
Aries's Avatar
I gave up on waiting on bottle heaters a long time ago.
Now I just carry a torch with me. The bottle heater just keeps it hot after the torch gets done.
Old 11-21-2003, 11:42 AM
The Bull
DERTY's Avatar
Man I certainly hope Darwin doesn't catch up to you.
A 15lb bottle will take a long time to heat up with one heater. Just do what Slow recommended and wire two of them in parallel. Or do what I do, use a Hot Box. But then that requires a generator or power at the track. Be prepared for your bottle warmers to wipe out your battery if you leave them unattended as well. They will draw a lot of current, especially when the car is not running.
Old 11-21-2003, 04:58 PM
bigSS's Avatar
will 2 heater pads make a noticeable difference?
perhaps I should downgrade to a 10lb bottle.... how much of a difference will that make?
Old 11-22-2003, 12:35 AM
bigSS's Avatar
I run a 100-150 wet shot... I am wondering if downgrading to a 10lb bottle is the way to go....
Old 11-22-2003, 10:32 AM
WOT
WOT's Avatar
just wondering how long of a time yu guys are talking about it taking for the 15 to heat up. i am curious as a 15 pound bottle is the way i was wanting to go? sorry to steal the thread but there has to be a way to have the best of both worlds?
Old 11-22-2003, 12:27 PM
Restricted User
CAT3's Avatar
Hell I thought about swapping for 2lb bottles, just swap em after each run of eliminations! Easier to heat, and more consistent(for tuning purposes).
