Stock bottem end nitrous build???
Old 08-08-2009, 03:43 PM
6th gear's Avatar
Default Stock bottem end nitrous build???
Ok so i am new to nitrous.I got my HSW kit about 6 months ago and cant get enough of the giggle gas.I was wanting to know what some of your N20 vets would do with my mods and a stock bottem end.Or if there is anything else i could get to make it run more efeciant.Thank you so much for you input.
LTs,CAI,3" exhaust,TSP Turqer v.2 cam,243 heads<<coming soon,monster clutch<<coming soon,HSW 125 wet shot.
When i get the car tuned i will be doing a 150 shot.
Old 08-08-2009, 03:50 PM
jmill96Z's Avatar
Sounds like you've got things pretty well handled to me. I wouldn't sweat hitting it with 200 if the tune is good. Once you get over that, I'd start looking at throwing a set of rod bolts in it.
The other thing would be to get the 243's worked. There are a few porters that have a damned good CNC program for them.
Old 08-08-2009, 04:17 PM
HitmanLS1's Avatar
My buddy has been spraying a 200 shot for 3years and its still running strong? Have you already updated the fuel system?
Old 08-09-2009, 09:21 AM
6th gear's Avatar
No that was going to be my next mod after everything else.Is your buudies motor fordged???
Old 08-09-2009, 01:45 PM
w3s1c0a5t's Avatar
Anyone thought about 317 heads on a 346 with the spray? Possible to run a bigger shot/or more timing with less compression?
I know in general this isnt the best way but Anyone think it might make more when the bottem end is so tender?
Old 08-09-2009, 06:44 PM
ryarbrough's Avatar
Lightbulb
Its not worth it to go low compression on a si nitrous motor.... nitrous LOVES compression... this isnt a fi setup
Old 08-19-2009, 02:05 PM
HitmanLS1's Avatar
NO stock bottom end.
Old 08-19-2009, 04:16 PM
BAKED's Avatar
I'd upgrade the fuel system before I upped the shot if I were you. Like Mike said, maybe get those heads worked and get some rod bolts. It also wouldn't be a bad idea to do head studs or at least ARP bolts when you do the head swap along with some GM MLS gaskets.
Old 08-19-2009, 04:22 PM
deathbydisplacement's Avatar
i will have to agree with others in this order fuel upgrade,rod bolts, head work
Old 08-19-2009, 04:25 PM
killaxtranz's Avatar
im running a 175 shot stock motor with exhaust 255 pump and lid
