solenoid ?
solenoid ?
whats a good sealer to put on the pipe threads that go into the noids.i know not to use tef tape.used tef paste and now have nitrous/fuel leak.i have installed systems before and they came with some kind red sealer.the only reason i used tef paste this time was the nitrous outlet instructions said to.
red it is then.hope there is no more leaks have grudge match real soon and need to test now.do you know how long i should let red stuff cure before i add fuel/nitrous?.
Red is generally stud strength, and blue is more of a removable. I use blue, and would rec using this on aluminum noids for sure. the red can be real tuff to get back apart, depending on the number. Any soft seal Teflon paste is alright too, but it can blow out under certain conditions if you put it in service right away, where as Loc tight will not, it's instant seal.
Robert
Robert
