At the track: need nano help
Correct, there is a regulator at the NANO, and a check valve on the nitrous bottle when the nitrous bottle pressure drops, the regulator will flow to the bottle to maintain a constant pressure of about 950.
Ideally it should be about 1050psi static and 950psi dynamic. I would see if maybe your gauge is off a little bit? Or maybe the NANO came from the factory adjusted a little low. we can set the pressure to what we want, but i would eliminate gauge issue first. My electronic gauge reads a little different compared to my bottle gauge, but the read points are at different locations. what does your a/f ratio look like? and does the psi return to 950psi after a run? may be nothing wrong here at all and in acceptable adjustment range from the factory? I am sure Tom or Brad will be along Monday or sooner.
Robert
Robert
Robert
Robert
Robert
