175 shot, upgrade pump & injectors?? Suggestions please.
Old 08-28-2009, 01:30 PM
01SOMZ28's Avatar
Default 175 shot, upgrade pump & injectors?? Suggestions please.
I was planning on spraying a 200 shot but i've changed my mind with that, haha. I'm now planning on doing a 175 shot and i was curious if i would need to get a bigger pump and/or upgrade the injectors as well? What else should i look into if i'm missing anything?
Old 08-29-2009, 10:55 AM
rggbly's Avatar
wet or dry first of all??
Old 08-29-2009, 03:24 PM
01SOMZ28's Avatar
its wet
Old 08-29-2009, 04:07 PM
1BadZ95's Avatar
I think you should be fine with stock injectors. I would get a pump for sure though. A walbro 255 would be just fine. If you can budget it grab some injectors, some 36# should set you for what ever you're looking to do. What plugs are you running?
Old 08-29-2009, 05:27 PM
w3s1c0a5t's Avatar
Wet has nothing to do with injectors. The pump is pretty much a must. And for any real purpose it would be silly to put a motor at risk for 100$.
walbro 255 would cover your bases.
If your really going to spray a shot of this size on a stock bottom end, Get the safety items as well sir.
Fuel pressure switch WOT switch of course.
Window switch honestly wouldnt hurt. I have seen autos spin hard enough into a shift that they hit the limiter.
Plugs will definitly need to be in the 7-8 range. non-projected tip being better.
Best of luck...
Pill it till you kill it.
Old 08-29-2009, 05:57 PM
01SOMZ28's Avatar
Best of luck...
I already have a WOT switch, digital window switch (on at 3200 off at 6000) and i'm running tr6 plugs and i actually just got done putting fresh ones in 5min ago.
Old 08-29-2009, 06:19 PM
brokenbird's Avatar
a pump would be a good idea but i have ran 175 for over 2 years and almost 40 bottles later its still running
Old 08-30-2009, 12:49 AM
srpoweredcoupeNWH's Avatar
You definitely need to go with at least some br7ef's on a shot that size. I personally wouldn't run a tr6 anything over a 100 shot.
Old 08-30-2009, 02:55 AM
w3s1c0a5t's Avatar
+346
Old 08-30-2009, 09:20 AM
01SOMZ28's Avatar
br7ef's? i've never hered of those
Old 08-30-2009, 09:35 AM
Mike@HSW's Avatar
BR7EF is a two step colder non-projected tip plug. For a 150+ shot thats what i would suggest as well.
Without a doubt, upgrade your pump to a racetronix kit.
Old 08-30-2009, 10:06 AM
01SOMZ28's Avatar
what about one of those ebay 255LPH for $100? haha
and i thought about converting my kit from the single nozzle to a plate, thats possible right?
Old 08-30-2009, 11:32 AM
MelScrilla's Avatar
converting to a plate shouldn't be a problem you just have to run your lines to the plate and remount the noids where they need to be.
And I'm pretty sure that the racetronic kit is just a Walboro 255 pump with everything you need to get it to work. If the ebay pump isnt name brand I wouldnt mess with it seeing that the TSP in tank kit with a Walboro only costs $139
Linkage:http://www.texas-speed.com/shop/item...d=225&catid=10
Old 08-30-2009, 03:08 PM
PowerShift408's Avatar
I would go with the Racetronix PnP kit with the hotwire upgrade. Do it once, do it right.
Old 08-30-2009, 03:15 PM
streetassasin's Avatar
thats what I have
