Plug gap on ngk8s!!
Old 08-31-2009, 05:35 PM
1badA3Z's Avatar
Default Plug gap on ngk8s!!
What should plugs be gapped at for 300 shot,motor is ls1,thanks!!
Old 08-31-2009, 08:59 PM
9sec93's Avatar
i would probably go a little colder than an 8. i used a 10 gapped at .027
Old 08-31-2009, 10:22 PM
1badA3Z's Avatar
Thanks,anybody else!!
Old 09-01-2009, 07:37 AM
ATVracr's Avatar
8 might be on the edge for a 300 shot depending on timing.
we run an 11 for anything over 200 in my car just to be safe.
your talking 5hp from using a plug thats to cold to melting **** from one thats to hot.
I would use a 10 and gap 28-25 thou.
Old 09-01-2009, 02:30 PM
1badA3Z's Avatar
How much timing do run with that plug atvracer,thanks!!
Old 09-01-2009, 03:01 PM
ATVracr's Avatar
Not knowing everything about the motor its just an estimated guess.... 16* Make a 1/8th mile hit and check the plugs. My guess is you'll be able to add timing but that "should" be safe timing wise.
Whats the rest of the tun up look like?
Old 09-01-2009, 05:41 PM
1badA3Z's Avatar
I will send you a pm atvracer,thanks!!
Old 09-02-2009, 12:33 PM
OutlawZ's Avatar
agreed... an 8 is too hot and right on the edge for that much spray. I use 10's up to a 300 shot gapped at .025.... we just switched to 11's and we're gapping those at .025 as well for what is currently a 325 shot....
we'll use the same for up to about 400hp.... ATV definitely has good insight on the timing as well.... I don't know what your base timing is but 16 is pretty safe.... at 325 we're at like 11 degrees...super safe.. base 32
Old 09-02-2009, 01:08 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
I have heard 6* per 100 shot for super safety.
