chacklist for a qucik 100 hit
Gonna try a 100 hit out on the street tonight hopefully. Car tuned with 29* advance now on motor, Gonna pull about 3* i think. pop in some TR6 plugs, maybe a couple gallons of 110 in the tank. How much should I fatten the AFR up? it's just a basic wet kit. It's been a long *** time since I've sprayed and I feel like a total noob all over again. Of course I'm shutting her down and puling a couple plugs asap after I spray.
Guest
Posts: n/a
If the car is know for runnig on the lean side you might need to fatten it up. Normally on a 100hp shot like Jmill96Z stated you shouldn't have to richen the car up. IF you were wanting to richen it up for the initial hit to be on the safer side then turn it back down that fine.
-Chris
-Chris
