I keep knocking out #7 plug
Old 09-08-2009, 10:37 AM
IH8FORD's Avatar
Default I keep knocking out #7 plug
My car keeps knocking out the #7 spark plug. It will idle for few minutes and knock it out every time. I have switched the coil pack and wire for the number one cylinder and the problem stayed on #7. All the other plugs look great. My next step is to swap the injector for one from #1 and see if it is the problem. Anyone have any other ideas if this doesn't work ?
Old 09-08-2009, 11:24 AM
LS1TECH Sponsor
Grant@NitroDaves's Avatar
is it fouling, melting or literally knocking it out of the threads?
Old 09-08-2009, 12:37 PM
IH8FORD's Avatar
Plug is fouled wet with fuel
Old 09-08-2009, 12:57 PM
ShiznityZ28's Avatar
compression check. no compression will not ignight the fuel.....
Old 09-08-2009, 02:13 PM
Race your car!
JL ws-6's Avatar
Sounds like the #7 piston/rings have an issue. I bet a compression check is gonna show you something you're not gonna like.
Old 09-08-2009, 03:08 PM
IH8FORD's Avatar
Just did a compression check and I have over 180 on all cylinders.
Old 09-08-2009, 03:29 PM
01 Red WS6's Avatar
Did you check the harness to that coil pack?
Old 09-08-2009, 03:36 PM
TARZAN's Avatar
Swap the injectors around and see what happens, it may be sticking open.
-Will
Old 09-08-2009, 05:56 PM
IH8FORD's Avatar
I will swap the injectors tomorrow and see what happens.
Old 09-08-2009, 08:20 PM
Race your car!
JL ws-6's Avatar
must be the injector... probably leaking when the things' supposed to be closed.
That's an easy fix, alot better then having to rip everything down that's for sure!
Old 09-09-2009, 10:20 AM
IH8FORD's Avatar
Yeah I was sick to think I would have to tear the engine down before I got to spray the **** out of it.
