n2o cutoff rpm
Old 09-18-2009, 04:33 PM
subhumanzz's Avatar
Default n2o cutoff rpm
just seeing around where i should be shutting it down. car is a m6, rev limiter is 6700 and i am spraying 100. i currently am spraying from 3k - 6150. can i safely take it higher? whats the highest rpm i should spray it to ?
Old 09-18-2009, 07:45 PM
Joinedthedarkside's Avatar
i see most people doing 200rpm before the rev limiter so 6500 for you
Old 09-18-2009, 07:49 PM
johnLs1camaro's Avatar
I have my spray turn on at 3000 and spray to 6600 and my car shifts at 6500. the limiter is at 6800. havent had any issues.
Old 09-19-2009, 03:54 PM
subhumanzz's Avatar
anyone else able to add there 2 cents?
Old 09-21-2009, 01:04 PM
Chris@NitroDaves
Guest
Posts: n/a
6500 is where i would set it
Old 09-21-2009, 08:16 PM
subhumanzz's Avatar
thanks.
Old 09-24-2009, 12:34 AM
robsquikz28's Avatar
200rpm is primarily where people tend to turn it off.
Old 09-24-2009, 12:57 AM
mitch cobb racing's Avatar
200 below limiter here, 200 above shift points
Old 09-24-2009, 08:32 AM
JAX04's Avatar
so those spraying 200 above shift points, are you actually spraying through the shift then? thats probably a stupid question, but, had to ask
Old 09-24-2009, 10:31 AM
^yep, we are spraying through the shifts..
