Another Spark Plug Question
Old 09-20-2009, 01:46 PM
MYSTIC-1SC's Avatar
Default Another Spark Plug Question
Ok i would like to hear your opinions on Autolites AR94 racing plug. My mods are in sig and i also would like to know gap recommendations for this plug. I have been previously told to run the gap anywhere between .035 to .038. Does that sound right? Also what NGK plug should i run if i don't go with the AR94s? Let me know what you guys think.
Old 09-20-2009, 03:43 PM
z28_YOU_HO's Avatar
What size shot are you running? Ive always heard TR6 is the way to go for a 75-150. Got all 8 of mine for like 20 bones
Old 09-20-2009, 08:14 PM
ATVracr's Avatar
stay away from autolites.
ngk br7ef
Old 09-21-2009, 01:38 PM
MYSTIC-1SC's Avatar
if the car was tuned with a certain plug shouldn't i continue to run that plug or is the
br7ef equivalent to the autolite ar94 as far as heat range goes?
Old 09-21-2009, 01:45 PM
ATVracr's Avatar
No, you can change it will be fine.
AR's are very hard if you hurt a plug using autolites your motor is DONE.
Ngks are much more forgiving.
I think the ar94's migh tbe slightly colder than 7's.
Old 09-21-2009, 01:54 PM
MYSTIC-1SC's Avatar
so try a tr7 then or stick to a tr6 since im only on 125 shot.
Old 09-21-2009, 02:08 PM
ATVracr's Avatar
Replied to your PM.
Br7 is what I would do.
Old 09-21-2009, 04:18 PM
MYSTIC-1SC's Avatar
ok well i ordered a set of the br7ef plugs. What do guys recommend i gap them to. My mods are in the sig and i don't spray on it a whole lot, and its only 125shot.
Old 09-21-2009, 04:32 PM
Destroyer of Exotics
FlashWS6's Avatar
where can ur buy the br7's?
Old 09-21-2009, 04:39 PM
MYSTIC-1SC's Avatar
i went to my local auto tire and parts and had them order me a set which should be here with a couple days
Old 03-10-2010, 10:02 PM
MYSTIC-1SC's Avatar
so guys refresh my memory what are you guys recommending my gap be for my ms3 car with full bolt ons and hsw wet plate kit pilled for 125 to 150shot.
Old 03-11-2010, 09:34 AM
kinglt-1's Avatar
gap them to .32
