Some success at last with n20
Old 09-29-2009, 06:29 PM
vettewrench's Avatar
Default Some success at last with n20
Took the corvette to the track on spray and had some good results. 9.68 @ 145 - 1.42 60 ft . 6 months ago we hurt a motor on the dyno and had to start over. Alot of you guys on this forum gave us some good advice to help us move on and get down the track . Thank you for that !! In 3 more weeks heading back to the track with coil overs,28 inch hoosiers and hopefully 100 % of n20 out the gate ! Tune up still soft so were going to creep up a little bit on it and then add some more jet. We did the above # with 28 n20 jets. Once again -thanks again to all
special thanks to ed hutcings from virginia speed -hes a super tuner !!!!!
Old 09-29-2009, 10:14 PM
MelScrilla's Avatar
sounds like your on the way. The only bad thing is in Jersey the racing season is about over at the end of October, I lived there for 19 years and I remeber going to Englishtown in October with heavy jacket, gloves, and a knit hat on.
You need to head south and get some passes in into the winter so next season you'll be running with the 275 big dogs.
Old 09-29-2009, 10:33 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
congrats, cold days are some of the best days!
windsor is no better! and at least you have elevation working even more for you!
Old 09-30-2009, 04:31 PM
Chris@NitroDaves
Guest
Posts: n/a
Good luck on the quest
Once you get that thing dialed in it's going to fly
