nitrous help (bogs and spitters)
well i installed my nx nitrous kit. and went out to test it.
i have a tps, fuel saftey, msd window switch. when i activate it, it just bogs and spitters and doesnt work and runs better without it. it also does it when not even at full throttle. i check all solenoids and tps switch. everything looks good and seems to work.
do i have some wiring wronge or is something not working right.
any help is appreicated
with the key in the on position i armed the system and the tps lit up, then put the pedal to the floor and it tures red whitch its suppose to. also when at idle and i arm the nitrous, the idle dips a tad like 50 rpms and when off goes back up. i dont know if its just a load or not
make sure its aimed rigth.my last wet system i had issues with it washing down the side of my throttle body. i had the same issue.and check your n2o lines to make sure there are no kinks.its a good starting point
how do you adjust the fpss, i bought the kit used and it was already hooked up to the fuel solenoid so i just hooked it up.
all wires good and grounded.
yes bottle is full
Guest
Posts: n/a
Sounds like your only spraying fuel. I'm willing to bet that its your fuel pressure safety switch. I would try adjusting it like Chris noted, or just wire it out. (for testing purposes only)
spark plugs gapped at 35
the part i dont understand is when i arm the nitrous it just turns on, when not in full throttle or in my window switch spot. and it drops my idle a bit when armed.
