TV2 cam and 100 shots
Old 10-14-2009, 12:01 AM
mikemunoz's Avatar
Default TV2 cam and 100 shots
like the title says how does the tv2 cam on a 112 lsa work with nitrous any info will help
Old 10-14-2009, 12:02 AM
mikemunoz's Avatar
plus my mods are in my signature
Old 10-14-2009, 11:56 AM
2002t/a06's Avatar
I think it would work well with good fuel support.
Old 10-14-2009, 11:58 AM
ShiznityZ28's Avatar
What are the specs on the TV2?
Old 10-14-2009, 12:01 PM
Chrome355z's Avatar
232/234 112+4 I believe.
Old 10-14-2009, 12:46 PM
Any cam will work for a 150-200 shot. Ideally id like 3-4 more degrees on the exhaust and on a 114 for a cam only 200 shot car. I don't think it will be bad though. Id back it out 2 degrees if you have an adjustable timming set.
Old 10-14-2009, 01:29 PM
Tony@Texas-Speed
Guest
Posts: n/a
The Torquer v2 is a great cam for a 150 shot with your setup
however, i don't see any fuel mods listed....you're definitely going to need a fuel pump
and yes, it is a 232/234
Old 10-14-2009, 09:31 PM
mikemunoz's Avatar
wont 150 be to much for a stock bottom end and what size injectors what should i go with and what brand
Old 10-14-2009, 09:40 PM
Hennytime's Avatar
150 is the standard for a stock bottom end
Old 10-14-2009, 11:12 PM
2002t/a06's Avatar
Your going to spray 150 dry? and no plenty of ppl are sprayin 150 with a stock bottom end.
Old 10-14-2009, 11:44 PM
mikemunoz's Avatar
150 wet but i haven't got the jets so im still debating witch one to get ether 100 or 150
Old 10-15-2009, 12:00 AM
supersick99z's Avatar
how many miles are on your car?
Old 10-15-2009, 12:47 AM
2002t/a06's Avatar
ohh just get a walbro255 intank fuel pump if ur gonna spray 150 wet. pretty cheap.
Old 10-15-2009, 02:03 AM
mikemunoz's Avatar
87,000 miles on it. 150 shot would i need to get bigger injectors
Quick Reply: TV2 cam and 100 shots
