Did ngk stop making the b8esf? part # 1049
I have been looking high and low for some b8efs plugs and 2 local retailers say they no longer make the plug and the rest seem to be out. What is a good substitute plug in this heat range besides the b8esf?
LS1TECH Sponsor
are you talking about the BR8EF whick is a non projected, 8 heat range, because the b8efs doesn't exists. you can add the "S" to the end which make the tip a screw on. napa should be able to order them all day for you or even carquest
B - 14mm thread diameter
8- Heat Range
EF - Tapered Seat .708" reach
S - Standard 2.5mm D Electrode
That's a breakdown of the NGK Part number
