What shot for dry system? lq4
Old 10-22-2009, 12:35 PM
rtpassini's Avatar
Default What shot for dry system? lq4
I will be putting an lq4 in my '80 T/A.
It will be powered by the zex 82020 fuel pump
http://www.atlanticspeed.com/product...gory=0#details
using this
http://www.summitracing.com/parts/CCA-82143#
is that pump going to be good enough? what shot should i use?
i dont want anything crazy. maybe 75?
Old 10-23-2009, 04:31 PM
Chris@NitroDaves
Guest
Posts: n/a
Are you going to be adding this pump to your existing fuel system or are you going to be running the car and nitrous soley off this pump?
Old 10-23-2009, 05:12 PM
rtpassini's Avatar
solely off this pump.
unless im mistaken, they dont make any in tank pumps for carb'd cars that will suffice.
so to make the lq4 work for my car, im just running this pump. then hoping to add nitrous. will it not be strong enough?
Old 10-27-2009, 04:27 PM
Chris@NitroDaves
Guest
Posts: n/a
As long as the fuel system is a return style system then you should be able to use it on the vehicle without a problem.
