Nitrous Outlet 2010 Camaro System and Accessories!
A month or so ago we introduced our 2010 Camaro product line up as we were finalizing up the final touches. I am pleased to offer a new post showing off all the final product designs except for one other dedicated fuel system that will be released at another date.
The Nitrous Outlet 2010 Nitrous system is the safest, best fitting, and most tuner friendly system on the market. From newly designed solenoids to prefabricated stainless hard lines there is no other nitrous system on the market that can offer the same sexy look and reliable horse power.
Unlike other brand nitrous systems on the market the Nitrous Outlet system is truly a system designed to fit your application. Other companies use universal solenoid brackets and have sloppy looking braided hoses lying all over the top of the engine. The Nitrous Outlet system comes with application specific hardware so that you will not have to order special fittings or different length hoses for a custom looking install. In return you get the best fitment with out the universal sloppy look.
Our 2010 Camaro System includes the following Features.
1. Newly designed high flowing solenoids built to work with today’s fuels.
2. The highest flowing, best atomizing and best fitting Nitrous Plate available!
3. Custom designed solenoid mounts.
4. Prefabricated Stainless Hard lines.
5. Precise fitment fittings.
6. CNC machined fuel feed with Prefabricated Hard line.
7. TPS extension Harness.
8. Neatly hides away under factory engine cover.
9. Bolts on using all factory equipment. (Including cold air box)
10. Wide range of accessories to work in conjunction with our nitrous system.
11. Capable of supporting Horse power levels up to 400 HP!
Wide Range of Bolt on Nitrous Accessories!
After we carefully designed our Nitrous system we did not stop there. Here is a list of our 2010 custom accessories.
1. Cup holder Nitrous switch panel.
2. Console Nitrous switch panel.
3. Custom bottle mount that will let you install your bottle with out drilling any holes in the car!
4. Dedicated fuel system
5. Billet heater adapter to work in conjunction with our billet bottle mount.
Picture of our 2010 Inferno Orange SS.
Nitrous System tucked under factory engine cover.
Nitrous System pictures.
Nitrous Outlet Custom bottle mount. With this bottle mount you can mount the bottle in the car using factory mounting locations. You can either use standard stainless bottle brackets or mount our billet bottle heater strait to the bottle mount. No drilling on the car. Installs and removes in less than a minute.
Nitrous Outlet Cup Holder Switch panel.
Nitrous Outlet Console switch panel. (test part, finished product will be laser etched)
Nitrous Outlet Progressive controller- Includes built in windowswitch, tps activation and gear lock outs.
Nitrous Outlet Dedicated fuel system
Here are links to these products on our website.
2010 Camaro Nitrous System.
http://www.nitrousoutlet.com/catalog...6&product=3925
2010 Camaro Bottle Mount.
http://www.nitrousoutlet.com/catalog...8&product=3956
Bottle Heater Adapter plate if using Nitrous Outlet billet bottle heater with bottle mount.
http://www.nitrousoutlet.com/catalog...8&product=3957
http://www.nitrousoutlet.com/catalog...0&product=3841
Console Switch panel.
http://www.nitrousoutlet.com/catalog...0&product=3960
Dedicated Fuel System.
http://www.nitrousoutlet.com/catalog...0&product=3959
If you have any questions please feel free to call us toll free at 1-866-648-7637
Thank you for your support!
Dave
Dave
