112 vs 114 lsa on juice.
I was debating on two different camshafts. Comp 216/220 with a 114lsa and the TR220/220 with a 112lsa. Both have a broad torque band and keep the rpms down, which is what I want.
Originally Posted by Damian
It's not going to make a bit of difference unless you're spraying 250+ shot of nitrous...
My best advice to people with street cars. Build it for optimal N/A performance first, then consider Nitrous icing on the cake...
josh
josh
I had a 224 .581 lift@112 lsa. I also had it retarded 2*. The best I could muster on the dyno was 495RWHP/520RWTQ.
Switched to a 228/234 .589/.598 @114 LSA intalled dot to dot. First dyno with only fuel correction to match the last time. No timing changes. made 525RWHP/615RWTQ.
Take it as you like. Ill stick with the 114.
Shawn
The 114 will have less overlap than the 112 cam, so the 114 cam should make higher cylinder pressures, so the 114 cam should make more power, but on smaller shots I dont think it will make that big of a difference.
I would not spray over 200 on a 112 lobe center. will it work... yes.... will it work for a while probably... the first time the car bogs on spray you WILL have a backfire. the reason N20 likes bigger LSA's is valve overlap. a 112 and lower are ground for NA high end power where overlap helps cylinder scavenging to suck more air in on top with a lower cylinder pressure at lower RPMS giving up torque. for those who might not know what overlap is "the amount of time in degrees both the intake and exhaust valve are open at the same time". with N20 you do not want as much overlap because once light it burns very fast and can create a situation where the cylinder pressure is bled off in the exhaust or in severe instances an intake backfire. there is a lot more to this but that is the lamens explaniation. I do not give up compresion with N20 but when building a N20 engine the camshaft is at least a 114 if not higher.
00redz28, where do you live in the mound? that is my old stomping grounds back in the day. We used to hang out at taco bell and various parking lots with my black z28 with yellow wheels.. it had quite a reputation for a while..
there are many cams out there designed for nitrous that have a 112 lsa. mine was, and a lot of people arespraying it with no probs. 114 would be better for the extremist that craves huge shots but i think more time is spent of the bottle vs. on. JMO
