Incagnito Kit
Incagnito Kit
Well i think this is what im going with. I want something small. Want 50hp jet. I like it because i could mount it under the dash, and turn the bottle on and off.I plan on having a 15lb bottle at home to recharge it with, If thats possible. I dont have a problem with a 10lb bottle on the back floorboard IF i could get the bottle unhooked and out fast like 2 min. Like using clips that hold the airlid closed on the bottle clamps,That same easy type clip. Also is it possible to have an air tool type Fittings on the bottle or do they have to be the screw on type. I have 2 babys that will be in the car every so often. I will only use the 50 shot 7-10 times a year. But i want it to be available all the time.From what i have read a 1.4lb bottle would last about 18-20 seconds with a 50shot. What do you all think?
A 1.4 bottle would give you maybe two good runs...then the next run would not be so good...Nitorus kits are designed to be used with 10-15 lb bottles...the pressure drops real fast on a little 1/4 bottle. Put a 10 or 15 in the well area, mount it to a board, and it can come out pretty fast.
Just curious about how this kit works.
Would it be comprable to purging into the intake manifold? The parts list for the 'incognito' kit is very small....seems as if basically, you would open the bottle, get some nitrous in your motor, and then floor it and burn up excess fuel...
seems pretty safe and simple for $220...
The incognito comes with a small solinoid.I have never had anyone call me back after buying one.I guess maybe thats good because if someone is unhappy normaly they will let you know.I would like to have some feed back on it.If you decide you want it.Call and ask for me.Ill hook you up if you promise to call me back and let me know how it works.
Dave
Dave
