How much would you spray at this set up?
Old 11-09-2009, 05:49 PM
455GTO's Avatar
Default How much would you spray at this set up?
455 pontiac block .30 over 463ci. Cast steel crank 4.210 stroke, forged pistons and rods 10.5:1 compression. Ported edelbrock performer heads flowing above 300cfm. 825 mighty demon carb. All through a th400 3700 stall on the trans brake. Have a plate set up but curious as to what my limit should be.
Old 11-09-2009, 07:34 PM
2002t/a06's Avatar
Through a plate I wouldnt spray more than 200, but thats my opinion..
Old 11-11-2009, 09:25 PM
RARON455's Avatar
On my 69 I had butler performance ported Iron heads (6x) on my 462 with the trw forged pistons and reworked rods, on a stock crank. was running a comp solid roller cam in it with the performer RPM intake and a holley 850. I had mine jetted for a 250 shot and made a ton of passes on the motor and never had any problems, just be sure to pull enough timing out of the car, your compression is a little higher than mine it was 9.75-1 but your running the aluminum heads, and can get away with it they dissapate the heat alot better.
Old 11-12-2009, 01:43 AM
455GTO's Avatar
Did you dyno the car? From doing research it says 700 is the limit on a cast steel crank... Thats what I am worried about. With my ported heads being done I should easily be close to 650whp which is close to the supposed limit... I have the msd high speed retard box so I will just put a pill in to pull timing. I am going to dyno the car once the heads are back on I just dont want to seize the motor on the dyno by spraying the 250 shot. What ET's were you getting on the bottle? Thanks for the imput
