What else do I need for a dry kit?
Old 12-02-2009, 09:14 PM
Atomic02's Avatar
Default What else do I need for a dry kit?
I have a universal ZEX dry kit can I use it and if so what else do I need? Or should I just sell and buy a Ls1 kit-whats different?
Old 12-03-2009, 12:37 AM
kinglt-1's Avatar
sell it and buy a plate kit from hsw or n20 outlet. Both companies make quality components for the ls platform. Do some research, that zex is junk for efi, their carb stuff seems to do ok tho.
Old 12-03-2009, 02:44 PM
Chris@NitroDaves
Guest
Posts: n/a
You can use the Zex kit on the car. I'd place the nozzle somewhere in the lid.
Old 12-05-2009, 09:07 PM
Atomic02's Avatar
What is a safe shot to run on a stock fuel system? I've heard 125 shouldn't be a problem.
Can I spray this much without worrying about damage. using a window switch and bottle heater with wot switch?
Old 12-06-2009, 07:53 PM
Nitro Dave's Nitrous Outlet's Avatar
Depends on what all is done to the car. The cars stock fuel pump is good for supporting about 450 total rear wheel hp. Injectors will be something you need to concider as well.
If it were mine I would sell the Zex system and put a good wet system on the car..
I see you are in Killen.. We are right down the road from you.
Dave
