Carb style plate?
Carb style plate?
Ive got a GMPP single plain intake with an elbow on the car, not carb'd but wondering if a carb plate would work between the elbow and the intake? If so which plate would you guys recommend? A nice 2 stage setup would be great.
Car is a 402, LS3 heads, 4L60, 3.73's, and a small yank. Looking to do an 80E swap soon
The Zex paremeter plate is a nice low budget plate that works well. I paid $230 for mine with the jets. Your question was why i went with it. I was concerned about airflow with the spray bars and 4 hole setups.
What I mean is where do you get your vacuum source from? Do you just tap into the brake booster hose or do you take vacuum off the throttle body from a vacuum port?
I just looked at the edelbrock T/B and I can't get a good enough picture to see if it has vacuum ports. Does anybody know if the Accufab T/B has vacuum ports?
The pro-flow is more in price when you include everything else.
**** I think the 2 stage pro-flow is more expensive the Speedtech.
Both make great products though. I also like SJ's plate
