WET or DRY on a small shot
I have a 01 cammed Z making 450hp/440tq. Car is a dedicated show car but makes its trip to the track every now and again. Looking at no more then a 75hp shop. With the sales going I am going to get a kit. What is best for such a small hit OR is it again one of those life long decisions. HAHA
Well if your tuner went for max effort on motor (ie. as much timing as it can handle), it would be ill advised to run any nitrous without running it on the dyno at the very least with some sort of data logging. Or have your tuner pull a couple degrees of timing globally or just from say 3k-limiter to be safe.. that should only take them minutes to accomplish and probably wouldn't even charge you for it. Then take it to the dyno and adjust the a/f ratio with your fuel jetting.
Good luck!
