What all do I need for a fuel pump change
Old 01-11-2010, 03:52 PM
TA1364's Avatar
Default What all do I need for a fuel pump change
Never done it, what all do I need?
I am thinking a racetronix pump and hotwire kit.
Old 01-11-2010, 03:53 PM
AChotrod's Avatar
and a cut off wheel for the trap door mod
Old 01-11-2010, 04:57 PM
Chris@NitroDaves
Guest
Posts: n/a
The Racetonix pump and hotwire harness will make the install very nice and the instructions are good too. If you do plan on doing the trap door mod then here is a good link to follow http://www.taekwondoplus.org/z28/fuelpump.html
Old 01-11-2010, 06:49 PM
TA1364's Avatar
I saw the pump on your site but where is the harness, maybe I missed it? Also about how long would it take to get it?
Old 01-11-2010, 07:52 PM
johnLs1camaro's Avatar
The pump and hot wire kit comes with everything needed and works great!
as for the trap door, never been a fan of cutting my car... dropping the tank is kind of a bitch though..
Old 01-11-2010, 08:03 PM
jman54002's Avatar
if you cut the car make sure you are sure you want to, you can't go back. If you cut it I did mine in 2.5 hours with the hot wire and that was the first time with a hot wire kit. If you drop the tank, add hours depending on the contion of the cat "rust". hoist would help alot but not everyone has one. have fun. But other wise pretty easy.
Old 01-12-2010, 11:30 AM
LS1TECH Sponsor
Grant@NitroDaves's Avatar
I assume by your sig you need pump and harness for 98'.
98' PUMP
98' HARNESS
Old 01-12-2010, 04:07 PM
john563's Avatar
dont tighten the clamps too tight on the tube..It could pinch it
Old 01-12-2010, 11:51 PM
TA1364's Avatar
Wouldnt want that to happen, then u might beat me this spring.
Old 01-13-2010, 06:53 AM
john563's Avatar
you'll need more than that 125 shot to beat me Got sumthin for your ***!
Old 01-14-2010, 10:09 AM
Nick@HSW's Avatar
Its not horrible to drop the tank...except on a 98. Either method will work, but just be very careful cutting if going that route and be sure to clean the tank off prior to opening it up. You don't want all that crap dropping into the tank.
Nick
