How much nitrous can an stock bottom end of a lt1 handle?
Guest
Posts: n/a
The motor should be able to handle a 150hp without a problem. It can hold 200hp but you tune / fueling and plugs ( it would be better to actually read the plugs ) needs to be spot on or something will happen and it wont be good. 200hp worth of nitrous is about the upper limit of most stock applications.
