Help with Nitrous outlet wet kit and tpp-00011
Hello,
Any one can help me with the wiring diagram of the tpp-00011 dual window switch with nitrous outlet single stage nitrous.
Thanks in advance.
Thanks in advance.
Guest
Posts: n/a
For the Tach you want to be looking on teh passenger side of the motor at the main coil plug
Once you got that then you are looking for the top row of wires and looking for the wire second from the left. It should be a solid green wire or green w/ white tracer or a turquoise colored wire
For the TPS signal you can go off the TB and you are looking for a Blue Wire ( This is if you still have the LS1 TB and Sensor )
If you have a DBW throttle Body then you will want to be looking for a Green ( Should be the rising voltage ) or a Purple wire ( Should be the falling voltage ). Either wire will work but one tends to work better than the other in most cases.
