2 bar dry shot
2 bar dry shot
anyone know if this will work. i have a 2 bar map sensor and big injectors. id like to spray a 150 dry shot. i have a mass air but the car is SD tuned. when the nitrous hits it should move above 100-105 kpa in hptuner. kinda like a blower or turbo car. can i add fuel in the 2 bar range for the dry shot? or is there a better way of doing a dry shot with a 2 bar?
this is for my vette, the last thing the camaro needs is some juice. i think i have it figured out. it might not be boost, but i think it will register over 105kpa. ill have to check to be 100%, even if it registers 110kpa, thats find, under boost enrichment i can richen it up for the shot
fuel enrichment table. and a resistor??
If you add nitrous then you need to add fuel. It has nothing to do with the 2-Bar MAP sensor. If the question is how should I add fuel with no MAF then I agree the IAT trick is a good method. The IAT trick is better even with a MAF.
Use a maf for 150 shot just make sure it is positioned right and it will work fine.
