damn fitament w/ power ring...
Old 12-22-2003, 12:03 PM
NOTFAST's Avatar
Default damn fitament w/ power ring...
what did you guys do to get everything to fit snug?
right now, my lid is duct taped on...i tried cutting down radiator shroud, cutting down the lid and cutting down the stock bellows...
any tricks?
Old 12-22-2003, 01:51 PM
EVIL's Avatar
good luck, mine never fit right
Old 12-22-2003, 04:32 PM
NOTFAST's Avatar
I might get me a FIPK...
Old 12-23-2003, 07:06 AM
4thGENRETARD's Avatar
I learned my lesson the harder way. As I live in a dusty environment, my previous RKsport lid never sealed properly and when cleaning my TB, I shined the light inside my intake and noticed there is dust that had caked itself all over the inside walls and runners.
Luckily as fate would have it the LS1 has a nasty habit of coating the intake with blow-by oil from the shitty PCV setup. The dust had mostly stuck to the oiled runners and there was no damage to the piston walls or rings.
I had to take the intake out to completely, clean it, and now I'm running FIPK GEN II with no more problems.
Amazing how a factory defect ended up saving my motor!!!
Old 12-23-2003, 11:11 AM
NOTFAST's Avatar
right now my airbox is sealed, but its with ducttape...i was just looking for something more 'factory' but its still all good
oh well, guess ill just keep the duct tape
Old 12-24-2003, 10:09 PM
U-Luze's Avatar
There is like 2 raised spots on your Maf on the front side if you look at it you can see it take and mark it with a magic marker what needs to be trimed, trim it all and take a heat gun ( I used one of out PVC welders we weld Plastic pipe with, it blow red hot stream of air) and heat up till plyable and workable. Stick it on there while hot and make it fit. Use some gloves and keep pressure on the plastic where it goes on the MAF and it will fit like a glove. I have some pic of what it looks like if someone can host them or i will E-mail them to u. Hope this helps Justin Hagerman
Old 12-24-2003, 10:48 PM
Fast SS on TNT's Avatar
I had to use radiator hose repair tape to seal up my trouble spots. Everything is tight, and halfway descent looking. But it was a ***** to get everything sealed up, and not look half assed. Great nitrous kit, all the way up til you have to start hacking your lid. Then it's a bitch.
Old 12-25-2003, 12:57 AM
taqwache's Avatar
lid definantly needs to be cut. if you carefully cut a little bit at a time, everything will match up nicely when done.
Old 12-25-2003, 11:52 AM
NOTFAST's Avatar
yeah, i got it to fit pretty good...still need duct tape but part of that problem is that I only have one air box clip
now just to finish up the rest of the install and be ready for spring!
Old 12-25-2003, 02:48 PM
BIGBOS's Avatar
I took my TB off to get it to pop on right when I had mine..........
Old 12-25-2003, 03:19 PM
taqwache's Avatar
yup, thats the best way to get it on there. i dont understand why they have to make it fit so tight like that.
