Paging Derty, my tune info...
Old 12-23-2003, 01:36 AM
Restricted User
CAT3's Avatar
Default Paging Derty, my tune info...
Hey man, I have my timing at 25.5* at max, during the whole run. No KR on or off Nitrous. I have my AFR at 12.6-12.8:1 NA, and only use the recommended jets for my shots. I dont swap tunes for street&track. I havent seen and KR in a long time, and yes I normally mix in about 2.5-3 gals of 101ul to about 1-2 gals 92octane pump.
Use TR6 plugs now at .033, bt am switching to TR5724-8 at .30 later. Plugs look clean, and timing mark is normally down at base of ground strap.
PPL say if I lower my AFR to around 11.1-11.5:1 and decrease timing to around 20* I will see a big improvement. I am curious so I might try it, seems I am losing more than gaining after this cam, could be bottle pressure, as I remember discussing this issue with you before. Will order a hotbox in about a month or so.
Thanks,
Charlie.
