running a dry kit
running a dry kit
im going to be running a dry kit on my lt1.. its full bolt on 6 spd cc306 cam, arp rod bolts, fresh rebuild with stock rotating assembely with arp bolts through out. i wanna know what i need to do to run this kit effectivly
im pretty sure this is the kit i got
http://www.holley.com/05177NOS.asp
it was from an ls1 and is a few years old
That particular kit relies on the maf to add fuel. Most conventional LT style kits utilize other means to add fuel. I would look into using the Interface to control the fueling.
Nick
Nick
Guest
Posts: n/a
Here are the instructions for the NOS LT1 Dry Kit ( Which differes greatly from the LS1 Version )
http://www.holley.com/data/Products/...135-SNOS-1.pdf
