Nitrous outlet plate/ with Nos solenoids
Old 02-08-2010, 07:40 PM
jman54002's Avatar
Default Nitrous outlet plate/ with Nos solenoids
Hey guys, I want to upgrade my plate system "78mm wet, ls6, NOS", to a Nitrous outlet 78mm plate . It already has the 6an feed line and the pro shot solenoid, plus the cheater fuel solenoid. So I only need the plate and jets...will this work or is there going the be a tunning issue? Any input would be helpful.
Old 02-08-2010, 08:23 PM
BayAreaSS's Avatar
I have something very close to that and it works fine. No issues at all
Old 02-08-2010, 08:36 PM
jman54002's Avatar
thanks for the input.
Old 02-08-2010, 09:02 PM
DiabloFormula's Avatar
Same here, had the NOS plate setup, then got myself a FAST 90/90 along with the 90 mm nitrous outlet plate, all you'll need to do is replace your jets, if I remember correctly, the nitrous outlet plate uses NX jets.
Old 02-09-2010, 08:21 AM
rpmauto's Avatar
I ran the same thing for 2 years, no issues. Just use the jets supplied with the plate. This winter i got the n2o outlet noids and intake brackets to clean things up a bit.
Old 02-10-2010, 10:28 AM
Chris@NitroDaves
Guest
Posts: n/a
As mentioned by the others you should have no problem with using our plate with thier noids, but you will have to use the jetting that comes with our plate conversion.
Old 02-10-2010, 05:12 PM
jman54002's Avatar
thanks Chris that is what I had hope for ...to spray 300 and NOS don't do that, yea yea no one should do that through an ls6 intake understood. But DP is not allowed in my group.
