Spray rocks! Just got kicked off the track!
Yes, at last! 10.87 at 122 mph. I just got kicked off the track in Gainesville for running a street car too fast! But it does feel great. Stock LS1/Trans Am + Vig. 3200 stall, TR 224 cam, TNT 200 shot, bolt ons, & tune = 10.87!!! Long live the LS1! And this is my only every day car, full weight with stock 3.23 gears. I hit the spray at the 60 ft. mark to save the rear end and then the bottle ran out around the 1000 ft. mark. I drove the car an hour to the track, embarrassed a couple of Ford trailer cars, got kicked off the track, and drove home all smiles. I believe the car has a 10.50 in it with a full bottle and 3.73 gears. If you want to run 10`s in a bad economy just put some spray on an LS1! LOL
Thanks guys! Yep, its a stock 10 bolt with 3.23 gears. I pulled the spare and jack but besides that its full weight. Well its WS6 Trans Am that I bought new so I don`t want to cut it up or put a cage in it. I guess that I`ll just have to wait till the end of the day to run 10`s.
this is the exact same scenario i want to play out for me come spring time!
Thanks LS1 nation!!! It runs 11.90 at 113 mph N/A and I run NGK 7 plugs on the spray and N/A. So you don`t think that I`ll pick up much ET by going to 3.73 gears? My average 60 ft. is only 1.70 on slicks. What about 4.10 gears in a 12 bolt?
Keep the 3.23s in the 10 bolt. They have a thicker pinion gear. I ran deep in the 10s with a 10 bolt. I switched to a 12 bolt Moser with 4.10 gears. I broke the ring and pinion on the 4th pass with it. I now have a Currie 9 inch and I can't break it. What size slick are you running? If you are running a 26" I would use a 3.73 gear and if it is a 28" tire then I would run 4.10s. BTW, awesome times for the mods you have. That is moving.
congrats on the time! wish i would have ran a 200 shot just for a little while. I put a hole in the block just running a 150 shot, but that was due to oiling issues not b/c of the shot.
