LT1 Nitrous Outlet plate Q's First time user.
Ok so I have a 94 z28 with 50k on it well maintained, im removing the powerdyne supercharger and replacing it with a nitrous outlet plate kit, the motor is stock except for full exhaust, 1.6 rr's, edelbrock 52mm TB, in-line fuel pump, and the PD which is coming off, im planning on running a 100 shot on the stock motor, is this ok? when I rebuild it it will have forged pistons and AI H/C but thats not until later in the year then I will be running a 150 shot, what do I need? will the motor last? I plan on having it tuned after the install.
How do you use nitrous? how many runs can I get on a 100 shot from a 10lb bottle? does it spray through all the gears? I have NEVER been in a nitrous car nor have I ever known anybody with it. its cheap here in cali. (2.97 lb) and I will probably go through one bottle a month once I spray a few times to get it out of my system how reliable are the N/O kits? will I have to worry about anything? school me please.
I would suggest using our digital windowswitch to controll the system. It will tell the system when you are at wide open throttle and with in the programed rpm.
Take some time and read this. http://www.nitroustech.com/forums/showthread.php?t=2
You can call us and talk one on one with a technical advisor and we can explain things to you from scratch.
Dave
