NANO kit and a Blowdown tube?
Old 02-24-2010, 11:58 PM
Pntbll309's Avatar
Default NANO kit and a Blowdown tube?
So Ive tried searching, but I cant find an answer. I think I know the answer but I am hoping I am wrong. Ive got the bottle mounted in the well where the passenger backseat was. Im looking at doing a NANO kit but need to do a blow down tube kit to keep it legal for the tracks....So how can I run the nano kit and a blow down tube?
Thanks for the help!
Old 02-25-2010, 12:01 AM
itsslow98's Avatar
nano hooks up to the gauge port and leaves access to the blow down tube connection....at least thats my understanding
Old 02-25-2010, 12:51 AM
Pwebbz28's Avatar
Correct. ^^^
Old 02-25-2010, 08:17 AM
Brad@NANO Direct's Avatar
Yes the NANO kit will hook into the gauge port. If your bottle valve does not have a gauge port you will need a NANO sport kit.
Old 02-26-2010, 12:40 AM
Pntbll309's Avatar
Pardon the stupid question, as Im a visual person, I lose the nitrous gauge on the bottle then correct?
Assuming I run a blow down tube, which I need to pass tech.
Old 02-26-2010, 01:30 AM
itsslow98's Avatar
yes, i believe you can run an adapter fitting off the gauge port so that you can have both the gauge and nano hookup, i dont have nano yet but i run my gauge on a fitting after the nitrous filter along the main line.
Old 02-26-2010, 05:19 AM
Beer99C5's Avatar
Some bottle valves have two ports. I switched my Dynotune bottle valve for an NX Valve.
Old 02-26-2010, 05:15 PM
16again's Avatar
I'm not using a bottle gauge. Have a pillar pod gauge instead.
Braided Blow down line on right.
Old 02-27-2010, 12:32 AM
JRracing's Avatar
I'm installing a nano kit right now and have a question.
Do you have to turn the bottles on or off in any certain order?
Old 02-27-2010, 01:07 PM
No either one first is fine. Normally the NANO on first then the nitrous bottle.
Old 02-27-2010, 01:59 PM
BakaN20's Avatar
Here is how I have mine:
The blue is the ss blow down tube port thingy.
I did it this way so I can always have a reading on the bottle even when it is closed, but I guess thats kind of pointless with a nano system, lol.
Old 02-27-2010, 03:06 PM
itsslow98's Avatar
baka, with the gauge there, arent you really only getting a reading of what pressure the nano is putting in the bottle and not what the bottle is putting out?
Old 02-27-2010, 03:26 PM
BakaN20's Avatar
I haven't been able to put it in since I got it in the fall and its been too cold, but here is my thought on it: If the nano is closed, it is still before the regulator, so whatever pressure the bottle is putting out, it is still being read by the gauge, get what I am saying? Bottle - gauge - Regulator - Nano
So when the Nano is closed, the regulator does not allow the nitrous to leave the bottle, so it is still being read.
Here is the other thing I am thinking, since the hpa/hpn the nano put in the nitrous bottle keeps it at 1050 psi static, would it matter if I have a gauge reading the bottle since it will always be at 1050 psi because the hpa/hpn will always fill up the empty space? I guess the only time there will be a pressure difference is when it is really cold or really hot, but generally, the pressure should always read 1050 psi?
Quick Reply: NANO kit and a Blowdown tube?
