125 dry shot????
No, not "SAFELY". if you have it set up to only pull timing when nitrous kit is armed or spraying, then it will not compromise your N/A tune. with only 125 shot, all you need is a good N/A tune anway.
I have a 100 dry shot sprayed through the MAF and I was told by a reputable tuning company that you can run full N/A timing and when the maf picks up the extra denser air that it automatically adjust your fuel tables to compensate. I hope I explained that right either way when I dyno'd my car N/A and on n20 my afr stayed a consistent 11.8 through the entire rpm range. I would definitely have some sort of means for your car to compensate for the extra "air" or it could go lean which is never good.
