best placement spot for wideband
I want to know where u guys using nitrous are putting the wideband sensors. Driver or passenger side? My exhaust Y's into a single after trans. How far away from heads? In front of or behind factory O2s? This will be used as a quick reference under WOT and I know best way to tune is to read plugs. Thanks in advance.
Oh will be using the afx wideband
On most headers there is normally a extra bung at the end of the collector just before your Y pipe. That is where mine is, just because it was already there and was easy to run the wire threw the drain plug in the driver floor pan. I have two sensor and two gauges. Reason being is Bank1 and be lean and Bank2 can be rich. So it is best to monitor both.
We have a few so we can move it around. the hottest cyl on an ls1 is 8. We like to use the passenger side in the collector and also put a bung ~10" from the exhaust valve on 8,7,1. 1 will be the coldest so you want to make sure your not going to far on the hot or cold cyl.
