got my bottle mounted
finally got around to working on the TA today, mounted the bottle using harris speed works' spare tire mount..also routed the blow down into the wheel well...im using an NX nitrous kit with the big carbon fiber selenoids and a shark nozzle mounted in a custom aluminum ring where the maf was, also going to be running HSW's microedge, br7ef plugs, frost's IAT module, etc..i will have more pics up as the install goes on..for now, enjoy!
At first I thought that was one of our spare tire mounts. I did not relize someone copied our spare tire mount.. Ohh well
Looks good though..and sure beats drilling holes in the inner fender well..
Dave
Dave
I posted a couple of shots on the where did you mount the microedge thread.
I already want to change the noid to nozzel lines because they stick out too much. Maybe next winter.
got everything just about buttoned up, still gotta run a few wires on the microedge and get the switches and plate installed..
mocked up
purge setup, we tweaked it a bit to fit better and trimmed the weather strip so it goes right through now..
almost there!
mocked up
almost there!
That fuel line is a little close to the power steering pulley for my taste. It would probably bounce and rub on our crappy roads. Other then that it looks good. I have a box of goodies on it's way from Harris right now.
Looks good, but dont the siphon tube in the bottle, point trowed the out let ? With the out let of the bottle pointing upward the siphon tube is pointing up,You might start loosing the liquid about haft bottle and go extremely rich, Just trying to help. but very nice install.
