T into fuel supply fuel line
Old 03-23-2010, 09:20 PM
veloxetmortifer's Avatar
Default T into fuel supply fuel line
I have a plate system from Nitro Dave and I have an after market fuel rail. Does anybody have a pic of where I can apply a T so that I can feed the nitrous plate with fuel? Thank you for your time.
Old 03-24-2010, 04:55 AM
berty's Avatar
i would like to see this as well
Old 03-24-2010, 08:52 AM
panterx1's Avatar
Several examples in here for feeding nitrous off of aftermarket fuel rails.
https://ls1tech.com/forums/fueling-i...uel-rails.html
Old 03-24-2010, 09:25 AM
Beer99C5's Avatar
Couldn't you drill and tap a 1/8 NPT thread into the rail, put a -4 AN male fitting to it, then run a -4 AN hose to the fuel Noid, then -3 AN to the plate?
Old 03-24-2010, 10:16 AM
Nick@HSW's Avatar
What size an hose are you running? Depending on the size shot, you can use one of these fittings in whatever size AN hose that you have:
6AN Adapter
Old 03-28-2010, 01:46 AM
It's a 4AN fitting that I need. The hose is a 4AN.
Old 03-28-2010, 11:23 AM
sprayedenali's Avatar
i think he meant what size fuel line?
you can put one of those fittings/adapters inline in the fuel line and it will have a 1/4NPT port in it
Old 03-28-2010, 11:43 PM
It's a 3/8 line with a 4AN fitting.
Old 03-29-2010, 12:41 AM
then get one of these -- http://www.nitrousoutlet.com/catalog...3&product=3786
and one of these -- http://www.nitrousoutlet.com/catalog...1&product=3749
or the same thing from HSW...
hope that helps and i didnt misunderstand what you are needing
Old 03-29-2010, 09:49 AM
Nick@HSW's Avatar
How do you have your rails plummed? Shoot me a picture of it and I'll give you a few other options to pull fuel from it.
Nick
Old 03-30-2010, 04:40 PM
Chris@NitroDaves
Guest
Posts: n/a
What size are the fittings that screw into the rails??
Old 03-30-2010, 09:11 PM
98mysticZ's Avatar
6AN Adapter
i just did this on my plate kit i got from nitrous outlet.. had to kinda make it work because i had aftermarket rails... ran a 90 of that and used a longer stainless solid line i had them send me to attach it.. works great
