N20 Outlet NO-61001 N20 controller?
I'm finishing up my heads/cam and N20 install on my 02 C5 6 speed and i've been looking at the Nitrous outlets NO61001 single stage progressive, TPS, RPM window switch w/ gear lockout controller for my car.
My questions are,
1) I also am using the LNC-002 Lingenfelter launch controller and i'm trying to figure out can i use this controller and my LPE launch controller at the same time? If i read the directions right it looks like i can only use the N20 in 2nd and so on gears?
2) And what wire do i tap into for the TPS input on the TB and the tach wire?
3) What wire on the N20 box do i use to trigger the orange wire on my LPE box to activate the timing retard? Is it the Pink wire or the white/yellow wire that triggers the solenoids? BTW the orange wire on the LPE box is needing a 12V+ input to trigger the retard.
thanks!
My questions are,
thanks!
