Just got a fuel pump, what else do I need?
Sup guys,
I always look at the brighter side of things like my fuel pump going bad : ) which leads to a new nitrous kit! So what would I need to run a 100 dry shot safely? Here are my biggest/related fuel mods,
1. Trex cam
2.42/lb an hr SVO fuel injectors
3.walbro 255 lph
4.all the basic bolt ons
The car makes 423 rwhp currently.
I am assuming I will need a fuel pressure safety switch, window switch, WOT switch. Anything else? Looking for any tips or advice, do I need a tune with a 100 dry shot? Thanks guys!
1. Trex cam
3.walbro 255 lph
You will need to go to a set of NGK BR7EF plugs. Do a racetronix kit on the fuel pump upgarde and it will support about 650 rear wheel hp.
You will need the system itself, bottle pressure gauge,bottle heater,fpss, nitrous filter, windowswitch.
If in the budget I would add the purge and nhra fitting with blow down tube.
You will need to tune the car no matter what power level. You nee dto varify airfuel and remove timing.
Dave
Dave
Sup guys,
1. Trex cam
3.walbro 255 lph
1. Trex cam
3.walbro 255 lph
For accessories, take a look at the all out accessory kit. It has pretty much every safety item all the way down to the plugs. The MicroEDGE controller, which is included, will handle your window switch, TPS as well as a bunch of other great features.
Nick
