nitrous purge?
Old 04-02-2010, 12:13 PM
01zb4c's Avatar
Default nitrous purge?
I want a big cloud of nitrous purge , what size line is everyone using? also copper, plastic, what is the best? thanks for any help!
heres what i mean as a "big cloud"
Old 04-02-2010, 01:09 PM
millersta's Avatar
look at nitrous outlet they are a sponser here im sure they will have what your lookin for
Old 04-02-2010, 01:35 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
check out our "Big Show" purge systems...
http://nitrousoutlet.com/catalog/cat...=23&section=80
Old 04-02-2010, 02:46 PM
brandoz28's Avatar
i use 3/16 brake line and can get a pretty good cloud. using a brand x purge
Old 04-02-2010, 04:37 PM
FiFdYnUtz's Avatar
i used brake line as well ^
Old 04-02-2010, 08:54 PM
01zb4c's Avatar
ok thanks guys. the tubing people use what is it exactly?
Old 04-02-2010, 09:26 PM
Mike@HSW's Avatar
might want to look at our showtime purge kit
http://www.harrisspeedworks.com/prod...6&cat=6&page=1
great price and will definitely give you the plume your looking for.
Old 04-07-2010, 09:56 AM
Chris@NitroDaves
Guest
Posts: n/a
Most purge kits utilize 3/16 Stainless Steel Tubing. Our Nitrous Outlet purge kits use a very nice and easily bendable aluminum.
Old 04-07-2010, 03:06 PM
01zb4c's Avatar
thanks for all the info and help. im going to use 3/16 line... whats the tubing people use, if they dont use metal.
Old 04-07-2010, 03:37 PM
NitrousBraden's Avatar
If you kinda crimp the line at the end it'll help with your cloud. I've had guys tell me about ice falling down on the car after a purge from doing that.
Old 04-07-2010, 04:20 PM
Chris@NitroDaves
Guest
Posts: n/a
you can use black poly line but will need a way to secure it to the vehicle so it doesn't plag around when purging.
Old 04-07-2010, 04:52 PM
BADMOON's Avatar
Zip tie. Thats what I had on my old setup on my old motor. That way if somebody thought I was sprayin and got curious with a slip of a knife no more purge hiding the soleniod was the tricky part..
Old 04-07-2010, 08:09 PM
Nick@HSW's Avatar
Flare the end of the tube that is exiting the car...I've found that this helps with the plume as well.
Nick
Old 04-07-2010, 10:18 PM
itsslow98's Avatar
make sure the pressure is up as well, thats significant with good high purges.
Old 04-07-2010, 10:48 PM
01zb4c's Avatar
thanks for all the help gonna start putting everything together here pretty soon... thanks again guys
Old 04-10-2010, 03:08 AM
rampag1979's Avatar
Remember that the weather plays a big factor in what your purge looks like also. Humidity is a big factor in this. I am running 3/16ths copper line on a 2 stage setup. Nice cloud..
Is this what your looking for.. The night this went down it was hot, muggy, and very humid.
My o'l pickup truck
My buddies car
And some badass mustang that was at the track.
Old 04-10-2010, 09:41 AM
01zb4c's Avatar
wow thats badass!!!!! very nice!
Old 04-10-2010, 07:44 PM
rampag1979's Avatar
Thanks and good luck with it..
Quick Reply: nitrous purge?
