Tach input wire
Guest
Posts: n/a
That looks like you came off the drivers side if i'm correct?? I've always and we always use the passenger side for pulling tach so i can't give you an honest opinion on wether it will work or not. From the looks of it you did the right thing main coil plug - top row of wires - second from the left, but i dont know if that will give you a proper signal or not.
What window switch is it that you are using??
