6.0 going spray
With what you have and the power levels you are going to be at I would suggest getting a great N/A based cam and it will work just fine with the nitrous.
As far as Nitrous goes. Either you can use one of our peremiter style plate systems or we can plumb a spray bar into the intake. With plumbing the spray bar in it will save you from spacing up the carb another 3/4 of an inch due to the nitrous plate.
Dave
Dave
N/A means naturally aspirated. He is saying buy a cam that will make good power on motor. Then just hit it with the spray. Since you are not planning on running a tremendous amount of nitrous and since it doesn't sound like its going to be a drag only car, this is the optimal set up. So decide what your goals are on motor and pick a cam accordingly. GOOD LUCK.
Nick
