No power with nos
No power with nos
Hello everyone i have a 1987 MONTE CARLO WITH A 383. i installed nos snipper kit installed it how the manual said but when i hit the wide open switch nothing happens no power gaings any ideas thanks
Yes itsslow98 i got it open lol. I know i have spray making it to the carb for when i hit the wide open throttle switch i can feel that booth solenoids are clicking ( with out car running ) and i can visually see the nitrous come up out of the carb. Just to make sure i moved the wot switch towards the throttle lever to be sure that it was hitting. Chris@NitroDaves Thank you for the wire diagram i checked over my wiring and it seems to be correct. I double checked the solenoid ground and moved it to a body ground location. Would i not get any power if my car was already running to rich? Thanks for the help
If you're not jetted for 700 psi, don't spray at that psi...Your a/f is gonna be way off. Run the pressure at the mfg's suggested rating to optimize the system.
nick
