Am I Overlooking Anything?
Old 04-15-2010, 01:45 PM
2002CamaroSS1982's Avatar
Default Am I Overlooking Anything?
My mods are in my sig, also included is a 255 Walbro in tank pump, going to run a wet kit on top of the 462 N/A rwhp my car makes and plan on spraying 100 to it, I was originally going to spray a 150 to it with a dedicated fuel cell but could I safely spray a 100 shot with an additional in line 255 Walbro, I also have 42.5# injectors already in the car those should be fine for a 100 shot shouldn't they?
Thanks,
Jeff
Old 04-16-2010, 03:00 PM
Anyone? Would just like to keep it simple, 100 shot on stock internals, dual 255lph pumps, and mix 100 and 93 in the tank when I decide to spray...any input?
Old 04-19-2010, 09:45 AM
YURVIEW's Avatar
Your single 255 should be fine for the hp level u will be hitting, so dual pumps will defintetly be adequate. Being that u are using a wet kit, ur injectors will be fine too. Just keep in mind that u are pushin limits of the stock internals and maybe passin the rated limits of the rod bolts. I too am running a set up similar to urs, 425 na w 100 shot on stock internals. So far so good. fingers crossed everytime tho.
Old 04-19-2010, 02:53 PM
Thanks, I haven't decided what to hit it with yet, a 100 or a 150. Guess it will depend on how ballsy I get once the kit is on.
Old 04-21-2010, 08:18 PM
blackls1ta00's Avatar
id start with the 100 hit first then go from there.
Old 04-21-2010, 08:37 PM
9Green-Z8's Avatar
is it a ls1 block?i have a similar set up and im looking to spray 150 but mines a lq4 block,and also does your pump have the hotwire kit?
Old 04-22-2010, 08:14 AM
Are you asking me? If so yeah its an LS1 block, I haven't done anything yet just bench building, but I had planned on keeping my injectors the same at 42.5# and adding a 255 lph Walbro in-line pump.
Old 04-22-2010, 05:29 PM
Chris@NitroDaves
Guest
Posts: n/a
You should be able to do what you are wanting on the two pumps.
Old 04-23-2010, 10:20 AM
Great! Thanks Chris.
Old 04-23-2010, 11:47 AM
Chris@NitroDaves
Guest
Posts: n/a
Your Welcome
Old 04-23-2010, 03:37 PM
9Green-Z8's Avatar
a question so he is running two fuel pumps?the stock and a walbro or dual walbros?because i have a racetronix with the hotwire kit but its just one pump wondering if thats enough for my set up,Thank yall for the help
Old 04-23-2010, 04:00 PM
Chris@NitroDaves
Guest
Posts: n/a
From my understanding he is running a Walbro in the tank and is going to be running one inline as well.
The setup you have should net you fueling capable of supporting over 630RWHP so unless you plan on making more than that you should be covered.
Old 04-23-2010, 04:10 PM
Correct, I am already running a 255lph Walbro in tank and will be running another one in line.
Jeff
Old 04-24-2010, 02:02 AM
9Green-Z8's Avatar
forgive my ignorance but how does the inline work,were do you locate that?
Old 04-24-2010, 02:04 AM
9Green-Z8's Avatar
and sorry for not posting earlier my set up i tought i had already its a lq4 block with patriot stg3 heads ms4 and i want to spray 175-200 i have the racetronix pump with the hot wire kit and i have 36lb injectors all ready to go
Old 04-24-2010, 10:59 AM
conde'strans's Avatar
X2! I would like to know this as well since I'm also planning on upgrading to a 200 shot.
Old 04-26-2010, 09:24 AM
If there is anyone in here that can better answer this feel free to chime in, but the inline pump is a supplemental pump that is in addition to your in tank pump that increases your fueling capacity, I usually just mount mine somewhere safe near the tank, some splicing is required.
